LT1 heads on LO3??
Old Nov 14, 2007 | 04:53 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
LT1 heads on LO3??
has any one ever put LT1 heads on there LO3 and lt1 cam? and if so how did it perform?
Old Nov 14, 2007 | 05:14 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: LT1 heads on LO3??
LT1 heads are reverse coolong heads, that motor isn't made to use them. It would be a very large mod to pull this off.
Old Nov 14, 2007 | 08:44 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Just put vortecs and an Lt1 cam. Vortecs are the same as LT1 heads but you can bolt them to your L03 with little to no modification. The only other thing you would need is a Vortec specific intake.
Old Nov 14, 2007 | 10:28 PM
Car: 89 Iroc z
Engine: 350 carbed
ok thx, wasnt sure
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
