TBI ??
Old Nov 22, 2007 | 04:21 PM
89maroconvrs's Avatar
TBI ??
i have a 305 with a tbi that runs real rich. It has a cam and has been rebuilt .30 over. is there neway i can adjust it?
Old Nov 22, 2007 | 04:37 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: TBI ??
buring a prom (new computer chip) for the modifications you have made, if everything else is fine possibly a fuel pressure regulator??? someone knowledgable about fuel would have to comment on that idea, but PROM is the main thing with this issue
Old Nov 24, 2007 | 07:16 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: TBI ??
Correct. With any cam swap chip work is needed. Without you won't be able to band aid the set-up enough to where it will run like it should. Fear not, there is plenty of info on this site to help walk you through the process.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
