System Looses Pressure
Old Nov 29, 2007 | 04:39 PM
kaupca's Avatar
Car: 92 Camaro RS
I have a 1992 RS camaro with TBI of course. When I check the fuel pressure with the engine running it is normal. After shutting the engine off pressure slowly drops until there is none. What are the possible causes? Isn't the system supposed to stay pressured up.
Old Nov 29, 2007 | 04:44 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: System Looses Pressure
kaupca
Nope, fuel pressure will bleed off through the Fuel Pump (there are no one way check valves as far as I know). Slow pressure drop is perfectly normal. As long as you are getting 11 to 14 PSI with engine running you should be ok for stock setup.
//RF
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
deracer
Apr 11, 2016 12:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
backtothe80s
Sep 5, 2015 12:39 AM
