Good external TBI fuel pump I can buy at the auto store?
Old Dec 18, 2007 | 10:39 PM
nat's Avatar
nat
I have a GM crate 350 with Vortec heads that I converted to TBI. I bought a nice pump from auto performance engineering, but I think I mounted it too close to the exhaust manifold, cause it is now only putting out 5psi and my daily driver is dead. I really need a pump tomorrow.
Did GM make any external fuel pumps for TBI? I have a part number for a master or airtex pump..........these any good?
Old Dec 18, 2007 | 11:17 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: Good external TBI fuel pump I can buy at the auto store?
did you have a intank pump in the car when it happened?
Old Dec 18, 2007 | 11:29 PM
nat's Avatar
nat
No.............I would prefer an intank pump, but my tank needs to be modified to use one.
I use my mechanical pump as a scavenger to feed the electric pump.
Old Dec 18, 2007 | 11:39 PM
Jproz1167's Avatar
bought a tpis pump once and left my intank pump in the tank and this tpis pump sucked something out of the intank pump and messed it up bad.... maybe yours got something from the mechanical pump.
you can also use a inline pump for tpi and TBI's regulator will cut the pressure down. I have a TPI intank pump in my car.
Old Dec 18, 2007 | 11:50 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Welcome to TGO
You may try (Master / Airtex - same company, different trade names) #E8094 which is rated 45-50 GPH gallons free flow and is good for stock TBI 11-15 PSI. I do not use Airtex pumps - I had good luck with Carter - P74017 pumps . Do not know about Delco external pumps....
//RF
Old Dec 19, 2007 | 10:39 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I've used the P74222 Carter pump (it's about 70 bucks) and it works okay, but not as good as an in tank TPI or Vortech pump.
It is used factory on a 6.5 turbo diesel truck.
Old Dec 20, 2007 | 11:36 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I've used a stock pump for a late 80's ford truck with the dual gas tanks. These pumps were external stock and supplied 42 psi abd enoug volume to feed a 351, it's fed my 300hp motor without a hickup.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
