What engine came in a 90 chev van?
Old Dec 21, 2007 | 04:38 PM
jamie660r's Avatar
Car: 91Bird
Engine: 305 TBI
Transmission: Tremec 3550
Axle/Gears: 3.42 auburn posi moser axles
I found a 1990 350 with computer out of a chevy van for cheap.What engine came in those and what is the hp? Would it be a good replacement for my 305tbi. Can i just swap engines and computers and bolt all my acc. from my 305 to the 350? Im new to the engine swap thing so thanks in advance for all the help
Old Dec 21, 2007 | 10:43 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: What engine came in a 90 chev van?
Its a TBI 350 with about 200 HP @ 4,400 rpm and 310 ft/lbs @ 2,800.
Swap the engine, the computer, using the 350 ESC module and Knock sensor. Use the 350 TBI injectors too as the van likely has the front-pull TBI on it.
All the accessories will swap right over.
Old Dec 22, 2007 | 09:23 AM
jamie660r's Avatar
Car: 91Bird
Engine: 305 TBI
What about the oil pan?Can i swap them too? Is there a way to get about 250hp out of this engine without custom prom burning? Will the computer give me any problems since im running a manual trans?
Thanks again
Old Dec 25, 2007 | 10:05 AM
jamie660r's Avatar
Car: 91Bird
Engine: 305 TBI
Would this engine be worth putting in to replace the 305? I can pick it up for around 400 with computer. Does anyone know if this engine has a roller cam in it? What would this engine be known as, lo5?
Thanks and merry christmas
Old Dec 25, 2007 | 04:39 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
I believe only the L05 in the cars were rollers but I'm not quite certain. I think the non roller L05 blocks have the provisions but didn't get the hardware. You'll need a cam, maybe some work on your cylinder heads depending on the cam you use, hedders and cat-back exhaust. You'll also need custom prom work but 250 should be easy to attain.
Gene
Old Dec 26, 2007 | 01:51 PM
jamie660r's Avatar
Car: 91Bird
Engine: 305 TBI
Thanks gene.I don't have a trustworthy machine shop anywhere close to me.It also looks like no matter which route i go im going to need a prom burnt. I just don't want to buy all the equipment to do it once.Let alone screw anything up. I guess i could put the engine in as is but would it be worth the trouble for 30 more hp?
Old Dec 26, 2007 | 02:18 PM
galvarado's Avatar
Car: 88 Camaro SC
You could use a cam from an LT1 engine. I believe the stock heads and springs will accept the lift of that cam. In order to run that cam you would need the spider tray, roller lifters, roller lifter retainers but you'll need to make sure the block is a roller block though it may not have a roller cam.
Gene
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 25, 2015 12:54 AM
89gtaforsale
Aug 24, 2015 09:32 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
