TPS adjustment
Old Jan 6, 2008 | 04:47 PM
icarus402001's Avatar
TPS adjustment
I attempted to adjust my RS's TPS today. Stock LO3. Luckily, I found I had .43v. at idle position, smoothly running up to 4.8v.at WOT position. I didn't have to move anything. I am confused though. Everything I've read on here says it's adjustable but nothing seems to be able to move. You can only remove it from the throttle body. The attachment screws are not through slots at all. Are the adjustments not possible or nexessary on a 92 LO3?
Old Jan 6, 2008 | 05:25 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: TPS adjustment
Nope, no adjustment on TBI's. The ECM self "zero's".
Old Jan 9, 2008 | 09:41 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Re: TPS adjustment
I dont know about your particular application but I had to elongate the holes in my TPS to allow it to rotate.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
