which engine block is best
Old Feb 12, 2008 | 10:02 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
well im going back and forth on this im looking into dropping a rebuilt engine in the car i want to go 350 tbi. wich is the best block to get for it, casting numbers would be great for you guys who have done this job. i want to just move up to a 350 and start off as a base from there i will not be doing anything crazy yet. ive seen lots of websites selling rebuilt engine for a good price i just dont want to mess with the whole junkyard and hope to find a good block and then rebuild. like i said im going to keep it basic just moving up toa 350 and i have read the 305 to 350 swap i just need to get a good engine now thanks alot guys
Old Feb 12, 2008 | 10:06 AM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
Re: which engine block is best
zz4 great motor
Old Feb 12, 2008 | 12:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Any roller block would do.
Old Feb 12, 2008 | 11:29 PM
camaro91's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: strange s60 4th gen width - 3.73
a good BLOCK is a 70's 010 block with the high nickel content. but if you want just a solid crate motor, a zz4 would be pretty good 355/405... sounds good to me!
Old Feb 13, 2008 | 01:27 PM
discostu's Avatar
That's a sham. The 010 was cast on pretty much everything, so the meaning got lost. The actual high nickel content lasted for about a year.
Nowadays, the only way to go is with a roller block. Anything less and you're just selling yourself short.
Old Feb 13, 2008 | 01:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Condition is far more important than casting numbers, metallurgy, or anything else.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
