Lifter Ticking
Old Mar 18, 2008 | 10:48 AM
wconn1979's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Lifter Ticking
I have a lifter Ticking and talked to a mechanic he said I should replace the whole engine?!?! I dont have the money for something like that. Any suggestions on how bad this is?
Old Mar 18, 2008 | 11:09 AM
wconn1979's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Lifter Ticking
Actualy I just have a ticking sound and took it into a mechanic and he told me it would be better just to replace the engine. Do you think this is the best option because if it is then I will just run the engine till it quits and then replace it.
Where is a good place to order a 305 or 350 engine and the wireing harness?
Old Mar 18, 2008 | 11:40 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Lifter Ticking
Alright, your getting ahead of yourself...
Are you sure its a lifter? If so, did you try changing the oil?
Old Mar 18, 2008 | 01:16 PM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
Re: Lifter Ticking
Before you completely change the oil, pull your oil filter off. Put in half a quart of transmission fluid if you have a short filter or a full quart if you have a long filter. Put on a new filter and crank the car. Drive it around for 10-20 miles or so. Then change your oil and filter as usual. If you have a lifter sticking, the transmission fluid will clean it off so it will go back to normal.
If that doesn't help, let us know.
Old Mar 18, 2008 | 01:51 PM
wconn1979's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Lifter Ticking
No I am not sure its a lifter ticking. Thats what the mechanic said it was. I will have the oil changed tomorrow and see the results.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
