TBI Backfire
Old Mar 22, 2008 | 11:58 AM
Sneakysportsman's Avatar
TBI Backfire
Hey Guys, I need a little help.
I have a backfireing issue with a built small block. Please don't expell me because it is in a truck. I have searched the web over for an answer to my problem.
Here is a rundown of what I have.
357 cu. in.
flat top pistons w/4 valve reliefs
96 vortec heads w/2.02in, 1.6ex 64cc, flat tappete with roller rockers 1.5
Edelbrock Air Gap intake, w/TBI 2" bore
Stock fuel pump
MSD Dist & Coil, 8mm Wires
Crane HI 6 Ignition
Edelbrock 3702 Cam
Duration at 0.006" Lift:Intake: 268°Exhaust: 288°Duration at 0.050" Lift:Intake: 194°Exhaust: 214°Lift at Cam:Intake: 0.265"Exhaust: 0.294"Lift at Valve:Intake: 0.398"Exhaust: 0.442"Timing at 0.050" lift:OpenCloseIntake:10° ATDC24° ABDCExhaust:44° BBDC10° BTDCCenterlines:Lobe Separation - 112°Intake
Full length 1 5/8 headers, 2 1/2 true dual exhaust with 40 series flowmasters.
I have my own programming software for the ECM so any suggestions would help.
Old Mar 22, 2008 | 04:22 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: TBI Backfire
Mine started backfiring when the cap + rotor went bad?? Started only when wet, then got worse till it was all the time. Had to replace the whole dizzy with a reman to fix it.
Old Mar 22, 2008 | 05:03 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: TBI Backfire
When does the backfire happen, full throttle,3/4 full throttle? does it idle normal? The first thing to usually check is your timing then check your TPS, IAC MAP sensors and any possible vacuum leaks.
Old Mar 22, 2008 | 07:21 PM
zap's Avatar
zap
Re: TBI Backfire
I will assume its when you hit the throttle, probably need to increase in the pumpshot area
Old Mar 22, 2008 | 08:16 PM
Re: TBI Backfire
I failed to mention a few things. When you first crank the engine and it is in open loop, or is running in start up mode, you can bump the throttle and the response is insane. Like 800 to 2800+ rpm in 100 th of a sec. After it warms up and goes into closed loop it will back fire thru the TBI @ 15% throttle opening. I have my own ECM Chip software so I can apply any suggestions.
I am thinking this,
I think the cam pulls too much vaccum and somewhere in the operating program the timing isn't retarding enough to accept the mix. The tuning is new to me so I am in a learning curve on what, where,& how to change things.
Old Mar 22, 2008 | 09:28 PM
zap's Avatar
zap
Re: TBI Backfire
Thought I recognize the screen name, Might consider a name change.
I have a secret!!!
http://www.fullsizechevy.com/forums/...400hp-tbi.html
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
racereese
Oct 3, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
