Injectors tapping
Old Apr 1, 2008 | 05:44 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Injectors tapping
I had to put a new intake manifold gasket on my 92 LO3 motor yesterday. So obviously I had to disconnect the TBI and everything else. I noticed when I reinstalled it that the injectors themselves are very loud. They are making a very loud tapping noise. I double checked all my connections and everything seems like its hooked up fine. Seems to be pulsating the fuel spray on both a tad as well. I didn't notice this before so I assume its something I did when I reinstalled it, but I'm lost. Anything that I could have done to cause this, or are my injectors just fried?
Old Apr 1, 2008 | 06:04 PM
Travis odell's Avatar
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
Re: Injectors tapping
sounds like everything is working right two me, the tapping sound is a good thing, when the injectors are not tapping and just dumping fuel in is a bad thing
Old Apr 1, 2008 | 06:58 PM
Car: 92 Z28
Cool, I'm just imagining things then. That or it seems like I inadvertantly advanced the timing a little so maybe it's dumping a little more fuel at idle. Either way, ahhh breathe easy, lol
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Did you put your air cleaner all back together and listen to it again? It's probably normal, TBI injectors are notoriously loud when they're exposed.
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
dimented24x7
Sep 6, 2015 03:51 PM
