Distributor Identification
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
Apparently there were two model number HEI distributors out there. I have a 1992 RS. I've got a little ignition problem and I just wondered if there was a way to visually tell the difference between the 1103749 and the 1103880?? Or is it just the difference between an in-cap and external coil HEI system. And does anyone know where to find these numbers where they are stamped into the distributor??
Car: check
Engine: check
Transmission: check
Re: Distributor Identification
The number is stamped into the bottom of the base plate. Of two small cap SBC distributors here one is 1103698 and the other is 1103952. The second was pulled from a full size van ('90-ish) with a 350.
One physical difference in the small cap distributors is for the B-body cars. The base where it enters the intake manifold is larger in diameter. Same with the opening in the intake manifold. This is to be able to r&r the distributor. The engine is set back under a little.
RBob.
RBob.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
'92RS
This is an old post, but it has some relevant information and side by side photos.
https://www.thirdgen.org/forums/tbi/...ghlight=b+body
//RF
//RF
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
