what would do this?
what would do this?
for the first few minutes after start up if the car is cold and you floor it, the engine doesn't respond. if you keep the foot to the floor it catches or if you let off a little. what would do this? after a few minutes it's fine.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: what would do this?
from the meager description you have given , i would first change fuel filter . then check fuel press. & injectors . good luck .
