low rpm tq 4x4 build
Old Apr 25, 2008 | 11:14 PM
Shaper's Avatar
I have a stock tbi 350 in a k5 blazer and I was wondering what you all thought about a good head cam choice with all the other bolt on products in place(intake headers etc.)
I am looking at the patriot heads and the EQ iron heads. And I cant think for the life of me what a cam profile would look like that would still work well with a tbi set up.
I am looking for the most low rpm tq I can get to move this pig up the hill. Anyone got any suggestions?
Old Apr 27, 2008 | 10:56 AM
Shaper's Avatar
Re: low rpm tq 4x4 build
wow, no input at all guys?
Old May 31, 2008 | 12:56 AM
brokenparts's Avatar
I'm bringing this back up to the top because I'm a 4x4 guy aswell looking to build my tbi motor. I'm looking for a good combo of parts... heads, cam, intake. etc. I've done a lot of reading and searching and havent found much yet.
Old May 31, 2008 | 01:22 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
This is a good read:
https://www.thirdgen.org/forums/tbi/...r-plus-12.html
//RF
Old May 31, 2008 | 01:43 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Vortec heads are the best stock sbc heads there are. There is a lot of info to read up on this subject. SD parts have upgraded ones for larger springs, or you can run 918 comp cams LS1 springs without modifying heads. You will need to machine the valve guides if you go over .475 lift.
Edelbrock e-techs are a great choice as well, but are about a grand.
I am building a 350 vortec right now with a LT-4 hotcam. I may do the work to use the stock heads or I may just buy the e-techs. I should just get a smaller cam, but what fun would that be.
Old May 31, 2008 | 07:42 AM
chupalupa's Avatar
Car: 1991 z28
Engine: L98 TPI
Transmission: Built 700R4
Axle/Gears: 3.23 posi
buy the big block buick 455 i have in my garage :P
jklein337
Sep 19, 2018 06:23 PM
overdriv
Aug 20, 2015 03:52 PM
Jake_92RS
Aug 17, 2015 09:42 AM
GVMV
Aug 16, 2015 08:01 PM
perZ
Aug 15, 2015 01:17 PM
