car wont start
Old Jun 4, 2008 | 06:33 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
car wont start
hi ive got a 90 camaro rs v8 LO3 and i cant get her to start. she worked fine and then i got her new spark plugs. afterwards she wouldnt start. i know the plugs and wires are where they should be. the problem from what i can tell seems to be a electrical problem. for whatever reason the injectors arent being told to spray fuel, but i cant figure out why. i have already installed a new ECM and still nothing. can anybody help me . i've been without my car for going on 3 weeks now
Old Jun 5, 2008 | 12:29 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: car wont start
'Skan
There could be a number of things that went wrong when you replaced plugs and wires.
1) Get DVM, check and see that you have +12 Volts at coil +B terminal (ignition key in run position and during cranking)
2) Check the two wire connector between dizzy and coil - check both sides for broken pins and wires.
3) Do you get spark when you crank engine over? If no, check ICM and reluctor coil. If you do get spark - check four pin connector plugged into ICM.
Perform above basic checks and let us know.
//RF
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
