tbi bucking when first starting out. Help!
Old Jun 9, 2008 | 11:50 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Anyone have any suggestions on why the motor would buck when I first start out in every gear? If I just give it a little gas, I don't have a problem. It seems to be gradually getting worse. I could check my filter, but after my revs get up, it can hold them. It's just the initial WOT that is a problem. Any help would be appreciated.
Old Jun 10, 2008 | 08:30 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: tbi bucking when first starting out. Help!
Check your TCC solenoid, and adjust your TV cable, or is this a manual trans.
Old Jun 11, 2008 | 05:52 AM
hot92RS's Avatar
Car: 92 Z-28
350, Thanx for the suggestions! Yes it is a manual. what is a Tcc solenoid? I see from your sig that you have a similiar engine. Have you had this happen before?
Old Jun 11, 2008 | 06:15 AM
bigj350's Avatar
Never mind, manual doesnt have either of those things. But a TCC solenoid, (Torque Converter Clutch) controls the converter when shifting. I had a problem like yours and I had put a computer in that was for a manual trans. Took me forever to figure that one out. Anywho, I would check you trans mount on the crossmember and the motor mounts.
Old Jun 11, 2008 | 02:32 PM
Ronny's Avatar
For me with a manual bucking was lean. I believe too much timing also causes bucking. I wonder if your fuel pressure is adequate? Consider datalogging to determine if fueling is issue. Verify fuel pressue.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
