fuel pressure guage
Car: 92RS
fuel pressure guage
I want to monitor fuel pressure. Wouldn't I need to install the guage on the return side to tell what pressure is at the injectors? I assume this is the side of the fuel circuit AFTER the fuel pressure regulator. Installing on the inlet only checks the pump, right? Does the CFM Tech adaptor install on the supply or return fitting?
I may be over thinking this but I'm about to start trying to tweak for mileage and there's no such thing as too much information.
Car: check
Engine: check
Transmission: check
Re: fuel pressure guage
It should go on the feed side as close to the TBI unit as feasible. Think of it this way: the regulator controls the pressure on the feed to the injectors. It does this by allowing any excess fuel back to the tank via the return line.
The feed side of the TBI uit is the drivers (US) side.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Also remember that the liquid filled gauge is only accurate at room temperature (72 F).
RBob.
Yes. The fuel enters the TBI unit via the feed port. It channeled to the area at the bottom of the injectors, then moves into and up past the injectors to another channel. This channel goes to the regulator which maintains the pressure on this incoming feed from the injectors.
Whatever fuel is not required to maintain the pressure goes through the regulator to the TBI unit's outlet/return port. Which returns back to the tank.
RBob.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
