help with identifying tbi unit+manifold
Old Jun 26, 2008 | 11:47 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hey guys,
as a matter of fact i just broke the housing on of my injectors in the process of putting everything back together after cleaning
so i need a replacement real quick, i have the opportunity to get a tbi unit that's supposed to be off a 305 van. the intake manifold says "W2" and GM14102182.
any1 got some more specific infos on that? i found something on the web saying it's off a 350, and the manifold seems to be the same on 305 and 350 tbi. just that it's the pre-86 design..
but does it have 350 injectors? and would it work to just replace the TB induction onto my L03?
thank you in advance guys,
every help is very much appreciated!
greetz ownor
Old Jun 26, 2008 | 01:04 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: help with identifying tbi unit+manifold
Originally Posted by ownor
hey guys,
greetz ownor
Thats one confusing post! Are you looking for injector itself or the whole TB assembly??? FWIW TB intake manifolds for 305 and 350 are identical - there is no difference. Insomuch injectors used for 305 and 350 are different. 305 injectors are color coded with white-green code and 350 is red-black. There are common part numbers - use search. TB pod can except either one.
//RF
Old Jun 26, 2008 | 01:18 PM
Ronny's Avatar
junk yard !
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
