what is the real base timing?i searched
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i searched on here i have read the different answers from 0 to 10 can someone plz tell me. it runs good at 0* but do i need to advance it ,and how much?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: what is the real base timing?i searched
Do you still have the labeling under your hood? That will tell you what the base timing should be. Usually its either 6 degrees for the older cars or 0 degrees for the 90+'s, but your stickers under the hood should tell you for sure.
I'd be interested in finding out more on timing. I know what the posts say here (0 or 6). Unfortunately, I don' t have the sticker under the hood and the Chilton/Haynes say 6. I know I can play with it but thought I would ask first.
Thanks!
92 Camaro RS
305 TBI
Thanks!
92 Camaro RS
305 TBI
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
But TBI's are definitely set to zero degrees stock. You can bump that up to 4 or 6 degrees for a little more power, but be sure to set it back to zero before you go in for an emissions test.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
LG4's and TBI's are zero degrees. 305 and 350 TPI's are six degrees. 85-92 V6's are ten degrees. I dont know what L69's are supposed to be, nor do I know 82-84 V6's.
The LO3 heads are fast burn by design and thus don't necessitate any initial advance like TPI heads do (non fast burn). A few degrees can increase throttle response but your best fuel economy and emissions will be found at 0 degrees TDC, just as the factory sticker indicates.
Ghettobird52
Jul 5, 2024 11:18 PM
