Rich High Idle Success - 92 305 TBI
Hi All,
Wanted to share a success since it came from posts on Third Gen.
Have 92 Camaro 305TBI that suddenly started idling at 2 grand, black smoke at start up and drinking gas like it was free beer.
So, short answer....coolant temperature sensor. Car runs significantly better.
Based on input from the board I went after all the stuff I could do without spending money first....(because I hadn't found the CTS clue yet)
Checked vacuum lines (pulled off at source, then at destination). If there was a change, this would tell me there was a crack in the line.
ALDL codes - are there any to start with?
IAC - stick finger in IAC throat to see of idle changed (it didn't)
EGR - check that is would move
CTS - pull the plug off and see what happens (it worked).
Hopes this helps
Hopes this helps
