Stripped Bolt
Old Jul 16, 2008 | 05:55 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Stripped Bolt??
I am removing my smog pump and the 2 torx-head bolts in the bracket below the pump stripped. I am taking it to a friend's shop to get them drilled out. When I get those two bolts out is the pump going to be free or is it held on by anything else? This is very important because I can’t stay and finish the job of removing the hard lines, plugging the manifolds etc in his shop. So if the pump is gonna fall free after I remove those to Torx bolts I need to make some serious plans to figure out how to get the car home to finish, i.e figure out what size bolts they are and have a new one one hand that I can put in to replace the stripped on until I get home. Problem is, without pulling the bolts out to look at I don’t know what size bolt that will be.
Old Jul 16, 2008 | 08:17 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: Stripped Bolt??
try getting a bigger torx and hammering it in to the stripped torx bolt and attempt to remove it, i ended stripping mine and thats how i got mine out. i dont remember if there are any other bolts holding the smog pump on, but your friend should have a couple of bolts that should fit in the holes so you can get it home.
Old Jul 16, 2008 | 08:35 PM
Engine: 350 TBI
Re: Stripped Bolt??
i already tried to get it out with two types of extractors and I just mangled the bolt head. Then there are the clearance issues. My friend is a machinist with professional tools so I'm just gonna leave it up to him.
hopefully i will just be able to find a bolt there, but I don't wan to take a chance. Its not an auto shop that he works in. thanks for teh input
If anybody else knows whether there are more bolts I'd really like to know.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
fasteddi
Sep 10, 2015 09:32 AM
Jlanz55
Sep 6, 2015 07:28 PM
Amillionoh7
Sep 5, 2015 11:44 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
