vats fixed still interminnet start
Old Jul 17, 2008 | 04:40 PM
carmodder's Avatar
Car: 92 rs ,2000 a6 2.7t
Engine: 355 carbed,twin turbo v6
sorry for the long explanation but i want to get it all in
soo ive been having problems with the vats system and it ended up being a broken wire to the lock cylinder so i fixed that and over the passed week its been giving me trouble again not wanting to start but if i walk away for a half hour or so and come back most of the time it would start.security light would not go off so i knew it was vats related. today its all screwd up very hot day today went to go to work this morning and no start so i walk a way for a few come back a wala its starts got to work, go to leave no start again security lite on after a few it finally starts while on the highway she dies pull off the highway and try to start her back up and nothing but this time the security light turns off after 5 sec but still not starting cranked it a few times and it would start to crank for like a sec then stop but then it started after a few tries died again few seconds down the road but started right back up got it home shut it off ..but it wont turn back on again ..wtf electrical gremlins,ecu ? oh and the vats connector under the dash reads the correct ohms with the key in the ignition?
Old Jul 17, 2008 | 07:25 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: vats fixed still interminnet start
coincidental bad starter?
Old Jul 18, 2008 | 02:16 PM
carmodder's Avatar
well i think it has something to do with the starter but not the starter itself.went out today to do somem trouble shooting but she started so how am i suppose to trouble shoot when it starts
Old Jul 18, 2008 | 02:53 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Question; Each time you attempt to start it, do you hear the fuel pump prime?
Old Jul 18, 2008 | 03:02 PM
carmodder's Avatar
yes
Old Jul 18, 2008 | 03:09 PM
Wadebryant's Avatar
Will it crank over but not start? When running and it dies, does it just shut down or peter out slowly?
Old Jul 18, 2008 | 03:19 PM
carmodder's Avatar
does not crank it has only stalled three times all in one day the first time i was crusin at 65 on the highway just shut completly off finaly got it started after 10 min mashed the gas hopping it wouldent stall got around the conor and it stalled again but started got home shut if off wouldent start again let it sit for three hrs started up pull out step on the gas a bam she stalled but started and ran fine for a 1/2 hr of driving got home shut off and wouldent start again and today get it her and crank 4 times and started every time
the main problem is the interminnet starting not the stalling unless there from the same thing
Old Jul 18, 2008 | 03:28 PM
Wadebryant's Avatar
Might be related. Even with a vats issue it should still turn over. So, I'd rule that out since you've made that repair. You might want to check the ignition switch and start enable relay. Before you go there, are your battery cables and the battery in good condition? No shorts to ground?
Old Jul 18, 2008 | 03:48 PM
carmodder's Avatar
the battery and cables are fine when i looked under the dash to find the enable relay i found a spot where a relay was suppose to be but was not.. it had a brown green blue and yellow wire going is that it? but ive never had problems like this before. the ignition switch was replaced like a year ago but maybe it came loose so i will check that when i get a chance
Old Jul 19, 2008 | 04:20 PM
carmodder's Avatar
ok so i replaced the ignition module and the ignition coil car ran smoother with a nice idle didnt stall but didnt drive her hard either but got home and bam wont start again so i jump the starter and bam she starts right up shut off let sit for 10 mins and she starts fine with the key again.. so im gonna relocate the starter selonoid and hope thats the problem
Old Jul 20, 2008 | 06:28 PM
carmodder's Avatar
so i put in a remote selonoid from a tbi mustang part #f492 $10 from the parts store a new battery cable and a push button. the car still doesnt like to start with a key when its hot out but starts fine with the button.so im assuming the igniton switch is shot or mis adjusted. the car was still stalling but i found a dry rotted hose that goes to the egr valve and to what i belive is the evap canister and fixed that. also i advanced the timing 2* and so far its been running fine ..ill keep updating
Glowsock
Jul 24, 2025 03:15 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
