How the heck does the coil mount on the manifold???
Old Jun 25, 2008 | 06:21 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Hey all,
I'm trying to figure out how the coil mounts on the TBI manifold.....it seems likie I'm missing a bracket.
Could someone look at the pictures and verify this....please help
Old Jun 25, 2008 | 06:31 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: How the heck does the coil mount on the manifold???
Um, 2 bolts through the two holes and into the manifold? Am I missing something?
Old Jun 25, 2008 | 06:40 PM
Car: 1971 Camaro
that's as far as it goes because the bottom part is hitting the manifold edge, it won't line up.....plus the top of the coil hits the air cleaner base
Old Jun 26, 2008 | 12:09 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
turn it around.
Old Jun 26, 2008 | 07:49 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
i think that those brackets are supposed to be together, not split by the coil.
Old Jun 26, 2008 | 09:51 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
2 things come to mind, either you have the brackets backwards, or they are both the same bracket.
look where i have circled the bracket in red at & see if the other bracket has less of a lip on it in that area. if it does swap the brackets around & see how it fits.
if they are the same, you can grind the bracket down till it clears the intake in the area where i have it circled.
the green line is about how much needs to be removed if they are the same.
also, flip the bolt around so the head of the bolt is closest to the TBI.
Attached Thumbnails How the heck does the coil mount on the manifold???-adscf2503.jpg
Old Jun 26, 2008 | 11:17 PM
RicksIroc86's Avatar
Car: 84 camaro z28
mine was like that and so i just screwed down one of the bolts and it works
Old Jun 27, 2008 | 06:03 AM
Car: 1971 Camaro
Thanks for the suggestions, I got it off a TBI camaro at the pull-a-part at the way they position the cars in the air I couldn't see how it was mounted when I leaned over to take it off. I'm not even sure if it was lined up with the holes when it was on that car.
I may play with the bracket a bit and see what I can come up with
But someone....anyone....with a stock TBI engine could pull the air cleaner, grab a camera, snap a quick picture of how there's is mounted it would be much appreciated
Last edited by 88TransAmFreak; Jun 27, 2008 at 06:06 AM. Reason: Automerged Doublepost
Old Jun 27, 2008 | 11:28 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
on my car the coil tower is closest to the distributor and the plug in is the opposite way, so i say turn it around.
Old Jun 27, 2008 | 11:23 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Can the two parts of the bracket be mated together and mounted on one side of the coil, where one part of the bracket passes underneath the coil? That might allow you to mount it in the location in the picture.
On my engine, I modified just one of the brackets to mount the coil lower than the stock position in order to clear an open element air cleaner. It only uses the modified bracket and the mounting hole furthest away from the distributor. I won't be able to get you a pic of it for a little over a week though.
Old Jun 27, 2008 | 11:37 PM
mesterz2889's Avatar
looks like you got a bolt to tap out anyway
Old Jul 3, 2008 | 08:41 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
It looks like your bracket is wrong.
Here are the best pics I could get:
Attached Thumbnails How the heck does the coil mount on the manifold???-go-031.jpg   How the heck does the coil mount on the manifold???-go-032.jpg   How the heck does the coil mount on the manifold???-go-033.jpg
Old Jul 20, 2008 | 06:23 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Here are pics of my modified coil mount to provide clearance for a drop base air cleaner. The first pic is the stock mount removed from the coil and its orientation as I remember it. The 2nd is half of the mount that I modified so it can be flipped over and clear the epxoy encapsulated coil. You can also see a couple washers attached to provide a little clearance w/ the manifold. The 3rd pic shows it assembled.
Attached Thumbnails How the heck does the coil mount on the manifold???-p1030753.jpg   How the heck does the coil mount on the manifold???-p1030754.jpg   How the heck does the coil mount on the manifold???-p1030756.jpg
Old Jul 20, 2008 | 06:30 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Here are pics of it installed. You can see how much lower the coil sits w/ respect to the distributor and throttle body. There's an air gap on all sides between the coil and manifold. The only thing that might be an issue is the limitation imposed on turning the distributor for timing. In my case it wasn't a problem.
Attached Thumbnails How the heck does the coil mount on the manifold???-p1030757.jpg   How the heck does the coil mount on the manifold???-p1030758.jpg   How the heck does the coil mount on the manifold???-p1030759.jpg
Terrell351
Jun 13, 2021 01:13 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
xxx3man`
Sep 23, 2015 10:37 PM
TheExaminer
Aug 25, 2015 07:34 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
