pop through tbi
Old Jul 20, 2008 | 08:04 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
pop through tbi
Ok, new issue since putting in zz4 cam. i am thinking that it is a lean pop through the tbi but im not sure and wanted to get some opinions. I have 350 injectors and a ported throttle body with a tpi fuel pump. right now my fuel pressure is at 14 psi. if i snap the throttle open it occasionally pops through the tbi with flames. i have not done prom tuning yet and realize i need to do it, but in the meantime can i get the car to run without the flames at wot without tuning? could it be a rich condition?
Old Jul 20, 2008 | 10:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: pop through tbi
Typical cause is going lean on the AE. Secondary cause is not enough spark advance. Basically, it is as you mention, it needs to be tuned.
You can try advancing the distributor 2 - 4 degrees. There is a good possibility that will help. Once you start tuning be sure to set the ECM calibration's Initial SA to what the distributor base setting is.
RBob.
Old Jul 22, 2008 | 04:20 PM
Engine: Built ls1
Axle/Gears: 3:42
Re: pop through tbi
Thanx RBob, i advanced timing a few degrees and it seemed to behave muchbetter, no popping. I decided to play around with the fuel pressure to see what would happen and when i dropped it down to the 11-12 psi it stumbled and popped through the tbi as it did before , so i put it back up to 15 psi and it was 100 times better no pop or anything. The biggest issue i have now is its running rich, which needs to be corrected through tuning.
db057
Jan 10, 2020 08:55 PM
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Racerx974
Sep 19, 2015 10:16 AM
Randomtask2
Sep 10, 2015 08:37 AM
