smog pump making ticking sounds?
Old Jul 22, 2008 | 12:03 AM
Demon_Eater's Avatar
Car: 91 Camaro RS
Recently I've been hearing this obnoxious loud ticking noises, and it's even louder then my exhaust (which sadly, my duel exhaust can be heard across town.)
Anyway, I thought it was my headers blew a gasket, but it was the smog pump, what would cause it to make ticking noises? i'll replace it later when I get the money (I got my new engine coming in two weeks, I soon will post pictures of it, )
Thanks,
Tim
Old Jul 22, 2008 | 12:58 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: smog pump making ticking sounds?
"dual" exhaust. A duel is a fight, dual means two.
A ticking noise from the air pump usually means the bearing in it has gone bad.
Old Jul 22, 2008 | 02:52 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Take it off and open it up. Put a little bearing grease in there and see what happens. Can't hurt.
Make triple sure it's the smog pump too. Use the long-rod-to-ear trick.
Old Jul 22, 2008 | 11:49 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
it could be the bearing in the pump or possible the plastc inside has broken and is boucing around inside thats what happened to mine
92camaroJoe
Jul 29, 2023 07:57 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 7, 2015 09:55 PM
