MSD 6AL for TBI?
Old Jul 25, 2008 | 05:02 PM
Z28XTC's Avatar
MSD 6AL for TBI?
Can you use these for a TBI? Are they a good mod to instal?
Old Jul 25, 2008 | 05:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: MSD 6AL for TBI?
You can use it. The only benefit it'll provide is a rev limiter.
Old Jul 27, 2008 | 01:52 AM
vjo90RS8's Avatar
Car: 2002 Z28
better things you can buy for the money. Even when I was an L03/thirdgen parts ***** I couldn't convince myself to buy this.
Old Jul 27, 2008 | 03:03 AM
Z28XTC's Avatar
I bought a IROC from junk yard for its wheels and rear end and this was on it so I was considering putting it on if its a wate of time I will just sell it.
Old Jul 27, 2008 | 10:53 AM
vjo90RS8's Avatar
Car: 2002 Z28
If you already have one might as well just throw it in. Make sure you use the GM dual connector coil MSD harness when you install it, should make the installation a lot easier. Maybe the IROC has the MSD harness also.
Old Jul 27, 2008 | 03:14 PM
Z28XTC's Avatar
Thanks I will check it out.
Old Jul 27, 2008 | 04:00 PM
blove78634's Avatar
Car: 88 Iroc
Engine: 5.0 TBI
Just my two cents. I installed this in my 88 Iroc w/ a set of E3 plugs. I noticed a huge difference in throttle response and power. It also fixed my tach jumjping all over the place. Then again I installed a complete MSD set up (wires, distributor, coil, msd 6al, and harness). The harness is key to the whole thing. Install was a snap with the harness. I installed the box behind the drv side headlight on the fender. However, a TGO member suggested a 93 coolant resivoir that will remove the stock coolant and a few mods to the battery box. The 93 resivoir acts as the resivoir and battery box. This is where I am going to move my msd box to (where the stock coolant tank is).
Old Jul 27, 2008 | 04:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If your tach was jumping, you had a misfire. Plugs and wires alone probably would have taken care of that. You would have noticed no difference if you'd had a properly working ignition before the box.
Old Jul 27, 2008 | 11:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The stock ignition system with an aftermarket coil is strong enough to fire off just about any mixture you can think of. Just make sure you have the "369" ignition module rather than the "048"
Old Jul 29, 2008 | 02:52 AM
fiveoformula's Avatar
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
how do you tell a 369?
Old Jul 31, 2008 | 04:34 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
any1 using these stock mount MSD coils like the GM Blaster or StreetFire? any other recommandations, and also what about that 369 module?
Old Jul 31, 2008 | 04:57 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Summit sells their own (off) brand of coil that says it's a direct GM replacement. Wonder if that would help out or if you would get what you paid for.
Old Aug 1, 2008 | 01:20 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
I bought the stock mount GM blaster coil along with an MSD cap and rotor. Should give better spark then stock. Ive never heard of anyone having problems with the stock replacement MSD stuff.
Old Aug 1, 2008 | 06:16 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
i bought the msd stock replacement coil and had meltdown of it in 15 mins of driving, and yes all the other components were new from wires to cap, except distribtor
Old Aug 1, 2008 | 06:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
048 and 369 modules
048 module pulls about 4* of timing above about 4,000 rpm while the 369 advances the timing 2* above 3,200 rpm.
Old Aug 2, 2008 | 04:05 AM
ownor's Avatar
Engine: LS1 / L03
what are you guys using for spark plugs? stock specs? just curious.
Fast, any info on the coil you are using? thx for the pic & #'s
Old Aug 2, 2008 | 10:37 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have an Accel Supercoil that I paid $5.00 for at a local junkyard from a TBI Truck/Van/SUV, I don't remember exactly what. To that junkyard a coil is a coil, a module is a module, a prom chip is a prom chip (bought various hypertech, JET, and ADS superchips for $2.00 just to read them) etc.
http://www.jegs.com/p/Accel/747628/10002/-1/10681
I am running AC Delco Rapidfires for a stock TBI 305 Van. I do have the gap bumped up to about .045" though from .035" stock. The spark from the Accel Supercoil is very hot even with the stock GM module.
Old Aug 6, 2008 | 03:22 AM
ownor's Avatar
Engine: LS1 / L03
i hope this is not too much of a thread hijack what i'm doin here, but would you use those rapidfires (gap?) on all tbis with the accel coil? if you feel this is a hijack let me know and maybe i can ask you a few more things via pm
thanks
Old Aug 8, 2008 | 04:48 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Originally Posted by Fast355
048 and 369 modules
One quick question if I may, where is the ignition module located in the car?
Old Aug 8, 2008 | 05:13 PM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
It's under the distributor cap. When you plug the two connectors into your distributor, they are plugging into that module. That's where you'll locate it.
Hope that helps.
Old Aug 8, 2008 | 07:16 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Hope that helps.
Thanks, that was what I needed to know. One more thing, I assume that when I get an MSD Pro-Billet Ready-to-Run distributor that I won't need to worry about the ignition module because the MSD distributor will have one already correct?
Old Aug 8, 2008 | 08:01 PM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
That is correct. The MSD "drop in" pro billet will come with a module (I believe it's MSD's own version). I have that exact MSD distributor in my 1992 Camaro and it has worked great on track and up to about 7,000 rpm (that's all the faster I've spun this engine). I like mine.
Old Aug 9, 2008 | 03:01 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Thanks, thats good to know. Now I have one less thing to worry about when I get my MSD Chevy Crate Engine ignition system.
Old Aug 10, 2008 | 01:14 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
what are the applications for these ignition modules? can i assume that the 048 module is for full size trucks? is this the same module that supposedly has a built in rev limiter?
Old Aug 10, 2008 | 04:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I never have looked at the module from a fullsize truck. The 048 came in some TBI F-bodies and B-bodies. I have seen a 454 RV that had the 048 in it. I know the 369 came in the 1990-1995 G20 Fullsize Vans with the L03 and L05 though. I also know the 369 came in the CPI 4.3 V6 S10s and M-vans. I don't know of a stock GM module that has a rev-limiter, but the high rpm retard will certainly make the engine fall over.
Fanatic1074
Oct 3, 2022 05:57 AM
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
