Injector ?
Old Aug 25, 2008 | 06:22 PM
Flip66's Avatar
Injector ?
My injectors were sent off and flow tested everything came back good the mist is much better now but I still have a small drip in them it is very small but you can see it at idle. Any ideal of what it might be
Old Aug 25, 2008 | 10:27 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Re: Injector ?
If it's not coming from the top of the injector pod, it's likely the o-rings that get installed along w/ the injectors. If I recall correctly, there's also a thin, narrow backup washer for the larger upper o-ring.
Old Aug 26, 2008 | 09:47 AM
Flip66's Avatar
Re: Injector ?
I have turned on the pump without the car running and there are no leaks I have let it run for a couple of min just to make sure there was not a slow one. It will only do it when the injector is working.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
