Dyno Numbers are in
Old Aug 28, 2008 | 03:44 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Dyno Numbers are in
well i went to they dyno today to test my current setup before i change my cam and heads and intake, My current set up is edelbrock performer intake lt1 cam 1.6 rr (i know heads are maxed out) 2400 stall 4.10 gears headers full exhaust and of course i tuned this combo with the ebl
186 hp
215 ft lbs
it was ran on a dynojet i think these numbers are a little low as to the fact that my afr dipped low at the start around 10-1 but stableized to about 12.5 let me know what you guys think thanks,
Mark
Old Aug 28, 2008 | 06:31 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Dyno Numbers are in
Nice, what other mods do you have?
Old Aug 28, 2008 | 07:44 PM
markymarco's Avatar
lets see hmm.... Ive got the smog delete msd probillet dizzy msd coil k&N open element subframe connectors bmr panhardbar relocation lca reloaction comp enginering panhardbar hurst dual gate.
also i forgot to mentinoon for anyh one in illinois do not go to finish line performance terrable service and they crushed my rear brake line and tried to blame me just a fyi
Old Aug 29, 2008 | 07:21 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
186hp @ 4500rpm? How much FP did it need?
Old Aug 29, 2008 | 10:27 AM
markymarco's Avatar
it was 186hp at 5400 rpm my fp is set at 14psi with 75lb injectors
Old Aug 29, 2008 | 10:30 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
those numbers arent too bad, considering the motor is 170 at the crank..
that puts you at what like 215hp @ the crank..thats not bad at all. Espec for what you have done to the motor. Makes me feel alittle better since im doing an lt1 cam and some mildly ported 601 heads in a few weeks.
5400 huh? thats a pretty high rpm to spin at (and make power)..i thought the heads gave up at like 4-4500 max. Well anyway, nice job.
Old Aug 29, 2008 | 10:48 AM
markymarco's Avatar
it pulls real healthy up to about 5500 then it falls on its face my new combo is a lt4 hotcam weiand stealth manifold 128 aluminum vette heads 5 angle valve job milled to 53cc fully port polished screw in studs and guideplates csr electric water pump im hoping for about 300 at the wheels
Old Aug 29, 2008 | 02:06 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
My car with just exhaust and fuel system did 145.9whp and I had more tq then you, 269wtq, but I think that was a flook on the torque because the highest on the run before was only 239, but thats still higher then you.
I would have expected higher with the cam and head work you have and plus the intake manifold, I would have thought 200ish hp
Old Aug 29, 2008 | 03:58 PM
thomas1976's Avatar
Car: 91 Trans am
Thats alot of fuel. Wat is the duty cicle at 5400rpm?
It would be interesting to dino it again, adding fuel by increasing the FP with the 55lb.
Did u ad a lot of SA to the EBL bin?
Almost not worth it all tese mods for 50hp.
Old Aug 31, 2008 | 11:38 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
anyone of you know how much drivetrain loss one can expect on these vehicles? also, i have to agree i would have expected at least 200whp from these mods. frankly, i'm a bit disappointed by those numbers..
Old Aug 31, 2008 | 10:33 PM
These numbers do seem abit on the low side. IIRC there are a few of us with fairly similar mods running better numbers. Somethings up. I agree that maybe the injectors might be a bit on the large side.
Old Sep 1, 2008 | 09:04 AM
markymarco's Avatar
im going to go ahead and try the 55lb injectors and retune a little bitand see what happens
Old Sep 1, 2008 | 11:49 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The timing advance curve will make or break you on the low-end. The flattop piston LE9 305 converted to TBI in my van with the stock 929 cam (194/203 @ .050, .390/.410" lift, 112* LSA), 14022601 heads, edelbrock performer rpm intake, stock TBI with stock exhaust manifolds and Y-pipe pulled this. Also don't forget that the peak torque on my engine was advertised at 2,000 rpm and peak HP at 3,600. The dyno operators did not start the pull until 3,500. By 3,500 the torque was already well on its way down. Peak HP was at about 3,600-3,700 rpm although it had a nearly flat curve all the way to 4,800. The ignition system components were tired and it was missing over 4,500.
Old Sep 1, 2008 | 12:30 PM
markymarco's Avatar
markstune1.txt heres m bin in text formnat
Old Sep 1, 2008 | 12:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Attachment 162974 heres m bin in text formnat
Two quick questions.
A.) What fuel do you have in IL? E10 or standard gasoline? If its E10 adjust your closed loop commanded air/fuel ratio to 14.2:1 and PE air/fuel ratio to 12.3:1.
B.) Is your distributor set to 5* advance like the calibration is. If the distributor is at the stock 0* setting, you have 5* retard across the board.
Old Sep 1, 2008 | 12:51 PM
markymarco's Avatar
im not sure if we have e10 fuel but yes my dizzy set at 5* initial
Old Sep 18, 2008 | 04:09 PM
bob8703's Avatar
thats not bad at all my 305 TPI put 175 HP and 256 TQ with an exhaust.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
