lt1 cam i.d. help please
Old Sep 4, 2008 | 03:15 PM
sweetk30's Avatar
Car: car? k30 1ton 4x4 truck
Engine: tbi 350 see sig line for mods
Transmission: th400 / np 205 tcase
Axle/Gears: dana 60ft corp 14ffrear 4.10 posi's
lt1 cam i.d. help please * with pics *
i got a used lt1 cam from a guy. didnt tell me what year. and from finding your super info thread/sticky i have found there is 3-4 diffrent cams.
well mine has a tinny fuel pump lobe on it but its all round no lump to run the pump rod. and on the cam just past that is ( gmpt bc 13 600 ) thats the only info on the cam i can find.
and help would be super thanks.
EDIT MORE INFO : checked the cam with caliper. found 1.5550 tall lobe then 1.2695 wide lobe for a diffrence of 286. this is super close specs not 100% perfect. then other lobe was 1.5575 tall and 1.2715 wide for 2.86 diffrence.
mabye this will help id the cam. i did look at the link in the swap post and 96 had close specs from lobe to lobe like this one minus the at .050 lift conversion.
i have posted a pic of the cam .
Attached Thumbnails lt1 cam i.d. help please-350-tbi-motor-build   lt1 cam i.d. help please-350-tbi-motor-build
Old Sep 4, 2008 | 03:19 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: lt1 cam i.d. help please
That number you listed is just a casting#. Unfortunately, it doesn't help to figure out what cam it is. The only way to tell is to find out the vehicle info.
This is the best info that I could find for stock LT1 cams:
93-95 LT1 202/207 @ 0.050" .450"/.460" Lift, LSA 116
96 LT1 200/207 @ 0.050" .447"/.459" LSA 117
Hope this helps!
Old Sep 5, 2008 | 06:47 PM
sweetk30's Avatar
ttt with pics of cam.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
