ZZ4 heads. Which gaskets and other questions.
Old Sep 12, 2008 | 02:39 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I've been pondering on just saying the hell with doing any work to my "187"s and just slapping in my ZZ4's to get a feel for them but I have a list of questions for those in the know.
1. Will I lose some bottom end "streetable" torque by switching these heads. They have been 3 angled, bowl blended, valves backcut, milled down quite abit and the combustion chambers are polished smooth.
2. What is a good head gasket to use? from what the machinist told me he milled them down .030 but I know they have been milled a touch before I got them. I want to get a good quench area and to maintain good compression. If I could get between 9.8 to 1 to 10.5 to 1 and be able to still run premium I'll be happy.
3. There obviously will be alittle overhang from the heads as they are built for a 4 inch bore. will this cause a decrease in effiency (spl?) Will this cause any problems?
4. how much of the 2 middle intake holes will I have to grind away to be able to bolt the intake down? will this cause any leaks?
I have most of the parts I need to do this but I'm just missing head gaskets to get this done. Some help would be greatly appreciated.
Old Sep 12, 2008 | 11:27 AM
Ronny's Avatar
Re: ZZ4 heads. Which gaskets and other questions.
I was just on Pace Chev and Gilbert Chev web site re: vortec heads. they strongly recommend not to try to adapt a traditional SB intake to head as they will leak. I believe Fast355 used a 2 barrel vortec manifold. He has photos and all on the thread. I never knew a vortec 2 barrel existed. Not sure if pricey. GM Vortec manifold is over $300
Old Sep 12, 2008 | 04:55 PM
ZZ4's aren't a vortec style. They have the standard 56-87 intake bolt pattern.
Old Sep 13, 2008 | 01:41 AM
One more question. Am I going to need guide plates? I will be using my stock push rods and from what i understand these heads originally came with guideplates.
Old Sep 13, 2008 | 05:41 PM
It can't be that hard of a question. I need some help here.
Old Sep 14, 2008 | 03:25 PM
Hi, some help here, please?
Old Sep 14, 2008 | 04:19 PM
Screw it I went with 10105117 .028" - 4.00 bore gasket from scoggin-dickey
Old Sep 14, 2008 | 06:41 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Shoulda just asked scoggin-dickey what they recommend
sheachopper
Jul 31, 2019 11:27 AM
gixxer92
May 18, 2017 11:20 AM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
