Brake issues...
Old Sep 14, 2008 | 09:55 PM
Shakermaker05's Avatar
Car: 1991 RS
Engine: 305 LO3
Axle/Gears: 2.73's : (
Brake issues...
Just took care of the leaking oil pressure switch and now...had the car on the road long enough to find out my brakes are not working real good. They do work, but not nearly as good as they should. I've had issues with the brake system in the past and a light has always come on in the dashboard. The light is not on now, so I hope this means its not serious. I checked the vacuum and it seems fine. The next thing I would assume would be the master cylinder but I just replaced it a few years ago. I just finished up a heads swap, but before I did that they (the brakes) worked fine. My dad thought it may be the booster. I thought I'd get on here and ask you guys what you thought.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
