Just a few tune up questions
Old Sep 23, 2008 | 02:50 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
The car is a 1991 RS LO3 with about 200k miles, I have no idea what plug wires to run, and I have ran a search, but no results really. Help me make sure I am picking the right parts before I waist my money please
ACDelco cheap plugs.
ACDelco Cheap rotor
MSD Dis Cap, cheapest available?
Then I was going to run some High Millage oil, What weight and brand does everyone like the best? Does the type of oil filter make any difference at all?
I dont want to cut cost and risk my engine or fuel millage, but I dont want to spend more than I have to either.
Old Sep 23, 2008 | 03:03 PM
Werewolf SS's Avatar
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
Re: Just a few tune up questions
Subsrcibed for anwser.
Old Sep 23, 2008 | 08:03 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Regular AC Delco plugs are the best for stockish cars.
If it leaks oil, go with higher weight [10w40, 10 or 20w50 if it leaks a lot] other then that just get synthetic 10w30
Use a good oil filter [Mobil 1]
For the wires just go to the parts store they will tell you what you need. Basically just regular old wires, nothing special needed for our cars.
If youre doing full ignition tune, go ahead and get an MSD or Accel Coil too.
I think its Jegs? I saw an MSD cap/rotor for like 24$ I think, Save you like 50cents and gets you all MSD, lol.
Might want to try so seafoam mixed in with your gas and some sucked in through the vaccum hoses also, I did it and it helped smooth my car out a little bit. But dont put it in your oil or it might leak more/start leaking.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
