drive belt bearing
Old Sep 24, 2008 | 11:56 AM
prazav8's Avatar
drive belt bearing
Hello, im thinking about changing bearings on drive belt because its quite noise. I already have new alternator and bearing in tensioner. I guess biggest noise maker is bearing at AC compressor and i found replacement part at rockauto.com. But other bearings is quite hard to find, there is water pump, air pump, P.S. pump and finally crankshaft. Its there a way to diagnose what bearing is about to go and whats good to go, since i cant disconnect part by part?
I also noticed time to time a high ticking noise when the engine idling, if im on passenger side outside of the car. I found in another tread its possible a smog pump, is there a way how to prove it?
Last question, i found small leak in the heater control valve. Some time ago a changed a coolant, there is some dry coolant on the tube, now its just a bit wet at the bottom of the heater control valve. Should i change it or its ok? Thanks for help, have a good one
Old Sep 28, 2008 | 10:12 AM
prazav8's Avatar
Re: drive belt bearing
Ok, i lost almost all of my fluid in expansion tank, its starting to leak more and more, so i have to get new heater control valve.
Old Sep 28, 2008 | 07:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
heater control valves are a common leak . fortunatly cheap , easy to change . do not forget other heater hoses & clamps . change all and avoid future problems . good luck .
1992 Trans Am
May 10, 2023 07:19 PM
red90IROCls1
Aug 25, 2015 06:56 AM
mcquigg
Aug 13, 2015 02:26 PM
gwade12
Aug 8, 2015 08:17 AM
