TBI Runs rich/smoke/no idle/Backfires through TB.
Old Sep 26, 2008 | 04:40 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Ok guys i wanted to run this past you.The vehical runs rough/misses/blows out smoke/won't idle. I'm thinking the computer is messed up. Anyways. It sounded to me like a MAP sensor. So i swapped it out. Nope.. Started testing the wires. Key on engine off I started probing. Its getting 5v ref. sending 4.6V back to computer. Thats right..right?? temp sensor varys in resistance too. No vac leaks. You really see those injectors dumping fuel at idle. Any Ideas??Thanks
Old Sep 26, 2008 | 08:04 PM
titchener's Avatar
Re: TBI Runs rich/smoke/no idle/Backfires through TB.
Take a look at this response:
https://www.thirdgen.org/forums/dfi-...ecm-issue.html
Paul T.
Old Sep 28, 2008 | 11:38 AM
Transmission: 4L80E
well i know that theinjectors are stock. The car was running fine. Now that I think of it I was welding on the back of it. Battery still connected. Did I burn up the PCM??
Old Nov 25, 2008 | 05:55 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
That is exactly how my car sounds. If I drive it it will try to choke out on acceleration probably because it's getting to much fuel. Sometimes when I try to start it, fuel will shoot out of the carb.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
