Tricking the IAT
Old Oct 3, 2008 | 04:34 PM
jackel200269's Avatar
Car: 92 camaro
Engine: lo3 v8
Axle/Gears: 10 bolt posi 4.10
Tricking the IAT
I have been searching for the information on which resistor a guy should use to send a cold air reading to the ecm. I now that the ecm sends 5 volts to the intake air temp sensor, and that the sensor adjusts voltage to the ecm depending on air temp. The colder the air, the higher the resistance or lower voltage. But what voltage is the IAT sending to the ecm when it is reading cold air.
Old Oct 4, 2008 | 04:44 AM
Icarus 402001's Avatar
Car: 92RS
Re: Tricking the IAT
5 volts. It's the current that changes. E=IR
Old Oct 13, 2008 | 04:02 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
you dont want to do this... your ecm needs that calculation to meter the fuel correctly. any gain in one small instance will be completely wiped out by power loss in every other.
timonator
Sep 30, 2015 12:52 PM
RS Reaper
Sep 27, 2015 07:04 PM
project89
Sep 22, 2015 09:35 PM
86White_T/A305
Sep 21, 2015 05:28 PM
BWilcox
Sep 20, 2015 12:19 PM
