good idea to put this intake on?
Old Oct 11, 2008 | 07:17 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
i am getting y car back from the tranny shop on monday. and i had this intake laying around. i have a tbi motor and want to keep it that way i have limited cash so would it be a good idea to put this intake on for more power and mpg? i know i would need an adapter plate. i was looking at the transgo adapter. any input or info would be greatly apreatiated!
Attached Thumbnails good idea to put this intake on?-photo0100.jpg   good idea to put this intake on?-photo0099.jpg   good idea to put this intake on?-photo0098.jpg
Old Oct 11, 2008 | 08:25 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: good idea to put this intake on?
Large single plane isnt the best option if your still near stock. Its probably an ok intake, but a dual plane with small runners would be better, something like an edel performer would do if you want to use a carb intake and adaptor.
Old Oct 11, 2008 | 08:28 PM
Car: 02wrx/88 rs
well its on the car in my sig. and like i said only thing laying around.would it help fuel econ? or power? or hurt it?
its a weiand 7546
Old Oct 12, 2008 | 12:42 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Its only a pair of gaskets and a few hours of work. I think you would like the single plane. I know I liked mine. Dewey316 ran one on a 305 with stock swirl ports and it ran out very well. A single plane intake on a TBI does not lose nearly as much low-end torque as a carb does. The engine will probably want a little more timing and more fuel pressure to run properly.
Old Oct 13, 2008 | 12:09 AM
Car: 88 Camaro SC
Engine: SFI'd 350
You'll also likely need to do some tuning due to the different AE requirements as well. That intake will likely want a lot of AE. Not quite as bad as a fully unheated intake, but it will need more than stock. Its not critical like it is with a manual, but if the AE is off, the engine may spit, pop, and fart from a standing high throttle start.
Old Oct 13, 2008 | 10:09 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
One more thing to consider when going with this intake is the TV cable bracket and correct adjustment of the same. Otherwise your 700R4 will sing a swan song in a short order. You may quickly discover that brackets alone may cost more than dual plane intake unless you can fab brackets that maintain correct throttle arm/cable end support geometry.
//RF
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
Jake_92RS
Aug 11, 2015 10:39 AM
