ebl help
Old Oct 17, 2008 | 05:42 PM
treeguy's Avatar
Car: 91 RS Camaro
Engine: Fast Burn 385
Axle/Gears: 4.10 True Trac
ebl help
what bin should i use ,385 fast burn,extreme efi tbi,85#police car inj.,afpr,20 psi. not really sure where to start
Old Oct 17, 2008 | 07:59 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: ebl help
Check CD that was shipped to you with EBL board. One of the calibrations is a stock 350 calibration. Use TunerPro to change BPW, but since you are running more cubes and bigger injectors that constant may remain more or less the same. There is a writeup in the docs supplied by Rbob....
//RF
Old Oct 18, 2008 | 10:21 PM
treeguy's Avatar
Car: 91 RS Camaro
Re: ebl help
alright,problem solved thanks for all the help,actually Rbob took time and made a start up program,and i changed my fouled plugs and like magic she had a heartbeat.lots to do still,but i think ill be out beatin up on our local supercharged 5.0 REAL SOON!!!
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
