HELP Changing Engine Whats better TBI or Carb
Old Oct 28, 2008 | 04:05 AM
chris0834's Avatar
Car: 89 camaro
Engine: 350 carb,headers,intake,cam
Transmission: automatic 700r4
Hi I am going to get my engine rebuilt. I have a tbi 350 in my 89 camaro but was thinking about putting a 350 carb. What would be better?. thanks
Old Oct 28, 2008 | 11:49 AM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Re: HELP Changing Engine Whats better TBI or Carb
TBI, you'll get great fuel economy and have the ability to generate some serious power. Plus TBI isn't as sensitive to changes in air pressure, temp, and other things as a carb is. However, you'll have to learn how to tune to use TBI. I'd recommend getting the Dynamic EFI EBL and a wide band O2 sensor so you begin to tune your TBI. Fast355 has a low 12's high 11's TBI car and he knows a ton about how to ge the most out of an EBL. Check out this link for more info:
https://www.thirdgen.org/forums/tbi/...free-tune.html
However, if this is too daunting for you, the carb is a nice option. You'll loose fuel economy, some performance in relation to enviroment, but all you need to work on a carb is some mechanical know how and a set of screwdrivers.
Hope this helps.
Old Oct 28, 2008 | 11:58 AM
chris0834's Avatar
Car: 89 camaro
Old Oct 28, 2008 | 06:23 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I swear by TBI and EBL, but carbs are cheaper. If cost becomes an issue, build it with a carb to get it running and save up for good injection. How much power you going for? Daily driver?
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
