NEED TBI fuel lines
Old 10-29-2008, 01:36 AM
chris0834's Avatar
Car: 89 camaro
Engine: 350 carb,headers,intake,cam
Transmission: automatic 700r4
NEED TBI fuel lines
I need the fuel lines that connectes from the tbi to the driver side engine conpartment does anybody have a set.
Old 10-31-2008, 01:11 AM
kcb37's Avatar
Re: NEED TBI fuel lines
If your not looking for a "factory" look, get a line from a parts store and bend it. Just take your time and you will be fine.
Old 10-31-2008, 01:43 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
bending is easier said than done, TBI lines, along with TPI lines use a special style flare(same a PS flares) that seal with an O-ring, ive got a set of lines, let me know if your interested, im in canada, if so PM me
Old 11-01-2008, 12:17 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Just an fyi some parts stores sell fuel line repair lines, some call them fuel tank of fuel sender repair lines. I got mine at CarQuest. They were 5 bucks each. They had the GM TBI type fitting and flare on one end and a regular flare on the other end. They had all different lengths. Any way it worked perfect between the TBI and the fuel filter. For the retrurn side I cut off the factory steel line were it was bad, flared it and got a brass connector. Worked great and was way cheaper than new lines. Cost less than 20 bucks and that included a cheap 5 dollar flare tool. Hope this helps.
Old 11-01-2008, 01:00 PM
chris0834's Avatar
Car: 89 camaro
cool thanks you the info
Frozer!!!
01-19-2024 04:55 PM
theshackle
03-05-2017 06:37 PM
Andrew6.688
12-13-2015 10:59 AM
AkDrifted
08-17-2015 07:45 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: NEED TBI fuel lines
