"INFL REST" waht does it mean?
Old Oct 31, 2008 | 06:59 PM
fivestar's Avatar
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
I have a 91 RS with the L03 engine and it will not start. I have a good battery and it cranks just fine just will not start. On the dash next to the 'service engine light' is a "INFL REST" light and it stays on all the time . I cannot find anything in the Haynes manual on this light can anyone help me understand what this means and perhaps let me know what I can do to fix this and if in fact this might be the cause of why my car will not start? All help and input is greatly appreciated.
Fivestar
Old Oct 31, 2008 | 07:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: "INFL REST" waht does it mean?
Inflatable Restraint. Nothing to do with your problem.
Old Oct 31, 2008 | 09:08 PM
fivestar's Avatar
Engine: IROC V-8
Thanks,
I just bought the car and am learning the differences between the 91 RS and my 88 IROC convertible. Still trying to figure out why it won't start, I will be checking on the codes tomorrow and perhaps get it running...otherwise I am going to put it in storage for the winter and work on a couple of other car projects during the cold months. Wish me luck and thanks!
Fivestar
Old Nov 5, 2008 | 07:12 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
hey if your ignition key has a chip in it you might need a new computer,lock cylinder and relay i had to do that to mine and cost me $1200
Old Nov 6, 2008 | 12:31 PM
fivestar's Avatar
Engine: IROC V-8
Re: "INFL REST" what does it mean?
Thanks for the replys,
I did figure out what was wrong and replaced the ignition module and the car started right up and ran smooth but smoked like all getout! It only smoked for about fifteen minutes or so then I turned off the car for another fifteen and started the RS again and significantly less smoke-whitish gray in color and did not smell like antifreeze so I think I might need to replace my valve stem seals-this sound about right to you out there?
Fivestar
Old Nov 6, 2008 | 03:43 PM
Car: 1991 Trans Am
Axle/Gears: Stock
yes i have to do the same to mine it just smokes when i start it so i called up jegs and asked them and they said its my valve stem seals getting weak
91BlkRS
Dec 18, 2005 10:04 PM
MrJ
Dec 19, 2001 03:00 AM
MouseCamaro305
Dec 18, 2001 09:32 PM
brihoop
Aug 10, 2001 02:45 PM
1blueRS
Jul 5, 2001 03:36 AM
