no spark
Old Nov 17, 2008 | 09:21 AM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
no spark
so ive been doing alot of reading about the ignition system just wondering if im correct in the assumption that if the distributor is bad then there will be no spark and the tbi injectors wont fire. right now im fighting this problem and ive replaced everything except for the distributor, i dont have a ohm meter or i would test the wires but they all look good and it just happened out of now where driving down the road the car just stopped running and hasn't started since
Old Nov 17, 2008 | 10:01 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: no spark
Get a DVM!! They are only $15 at most stores.
Just because component looks good means very little to electrons!
//RF
Old Nov 21, 2008 | 01:07 PM
wjiroc86's Avatar
Car: 1989 RS
Engine: 305 tbi, junk, freakin slow!
Transmission: 700r4... holds up =]
Re: no spark
i had this same problem last night,it died and wont start its got a couple month old jegs distributer and coil. i have no clue what it is but i hope its not the distributer
Old Nov 24, 2008 | 02:23 PM
wjiroc86's Avatar
Car: 1989 RS
Re: no spark
double post, i dont know if you figured out your problem but i took out my control module and put in my old one the car started right up first bump, i was pissed... but its fixed now.
Old Dec 7, 2008 | 11:04 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: no spark
sounds like the ignition module... just my .02
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
