55lb injectors on stock fuel pump
Old Apr 10, 2006 | 01:39 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
If I were to upgrade to the 55lbs injectors on my throttle body...would I need to replace the stock fuel pump as well or would the stock pump be ok?
Old Apr 10, 2006 | 04:10 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
stock pump will be ok
Old Apr 10, 2006 | 05:29 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
????? BTW, stock L03 305 injectors are 55 lb/hr!!!!
Old Apr 10, 2006 | 11:47 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Color code
Application
Flow rate
Part #
Black/White
1-3/8" bore 2bbl, from 2.8l truck
GM 5235430 *RPD
Yellow/Blue
4.3L
GM 5235203 *RPD
Green/White
5.0L
40 lb/hr
GM 5235279 *RPD
Orange/Black
5.7L pickup
55 lb/hr
GM 5235206 *RPD
Yellow/Brown
5.7L Cop Car
65 lb/hr
Old Apr 11, 2006 | 12:02 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That chart is somewhat out-dated. The STOCK injectors in the 305 TBI that I pulled off of a 305 truck were 55 lb/hr on a flowbench. Stock 350s are 61 lb/hr.
2.8 = 36 lb/hr
4.3 = 46 lb/hr
5.0 = 55 lb/hr
5.7 = 61 lb/hr
5.7 High Flow = 68 lb/hr
5.7 Vortec Van = 74 lb/hr
7.4 = Various ratings depending on year/application
Old Apr 12, 2006 | 12:22 AM
86z/92rs's Avatar
Before I did the 350 vortec swap on my 92 RS w/305, it had 5235279 on the injectors. Anyone else TBI land w/stock 305 have the same injectors?
Old Apr 13, 2006 | 08:11 PM
91V8Redbird's Avatar
Car: 91 V8 Firebird
Engine: LO3 305 TBI V8
Mine have that number on the injectors, as well as the green and white paint as mentioned above.
Old Dec 5, 2008 | 05:19 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: 55lb injectors on stock fuel pump
i have new ones in my firebird and they have a red top on one side it says
RI279 and on the other side it says 7124? i have no idead what thats telling me?
Old Dec 7, 2008 | 03:21 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
I have a bunch of 5206, 4304, 5231 injectors and have had them all flow tested, etc.
5235206 typically flow at 650cc/min to 700cc/min @ 1bar which is 14.7 psi. This means that a 5206 (stock 5.7L) injector ranges in the low 60's for lb/hr.
Increasing fuel pressure (if pump can handle it) will increase flow rate and HP. Most stock fuel pumps dont do well about 14-15psi especially at WOT, etc.
I have some 5235206 injectors that flow at 720cc/min @ 14.7psi
So.....
jklein337
Sep 19, 2018 06:23 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
