Is there such thing as a cam you don't need to tune for?
Old Nov 17, 2008 | 12:12 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
What I mean is: Is there a cam I could install that I would not have to Tune right then and there just to get your car to run and drive? A cam I could put in saturday and drive to work monday without learning to tune? And then tune it gradually as time passes and I learn/save for an EBL?
I have seen posts saying things like x cam is great but you will never get out of the driveway unless you tune etc. and it scares the heck out of me because i want to do exhaust, heads, intake and cam all at once and I am afraid I will screw up the cam trying to break it in since I can't tune. And I really don't want to turn a good running car into a yard decoration because I modded it and now it won't work... or worse yet have it leave me stranded somewere.
What to do?
Old Nov 17, 2008 | 08:27 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Is there such thing as a cam you don't need to tune for?
the car will run with many cams, lt1, l98, l31 etc...
Old Nov 17, 2008 | 10:55 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
The only cam I can think of that would still get you down the street would be the Vortec/L99 cam. It's VERY mild but it should be drivable on the stock tune. BUT... even a stock car can benefit with a tune.
10243779 191/196 - .418/.430 111 LSA
with 1.6 rockers 194/199 - .446/.459 111 LSA
Add an S10 L35 96+ 4.3 v6 converter 24202310 and new valve springs while you're at it for some more punch.
Old Nov 18, 2008 | 10:40 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
So truth be told... if I want to do a cam, intake, larger tbi, different heads,headers and full exhaust then there is no way around it I will need to learn how to tune?
Can I mail order a tune just to get the car running good enough to break in the new cam and even to drive back and forth to work for a while?
After that if I got the EBL how long would it take the average noobie to get it fully tuned?
Old Nov 19, 2008 | 11:21 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Mail ordering a tune is much easier if you're copying someone else's exact combination of parts. Simply adding better heads caused me issues with my TBI.
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
ezobens
Aug 19, 2015 10:29 PM
Bob88GTA
Aug 18, 2015 03:31 PM
355tpipickup
Aug 13, 2015 07:35 AM
