Trouble Starting and idle issues
Old Nov 25, 2008 | 07:31 PM
Sneaky Neil's Avatar
About a month ago, the 90' Formula starting having some starting issues. It will not start unless you give it some gas as you are cranking. It will try to start, but not quite catch if you don't give it gas. It will run rough for a few seconds, then settle into a normal smooth idle. I can hear the fuel pump go, although it seems quiet to me but I never really listened before.
After running the car to my destination, when I put it in park, the idle is around 1200 and it doesn't really drop below 1000 even after letting it sit for a few minutes. I have to turn it off at this idle speed even though i hate doing it.
What could be the problem? The plugs and wires are about a year old. The car smokes on start-up, but it has been doing that for a couple years. The car has about 150k on it. Thanks.
Old Nov 25, 2008 | 07:39 PM
Twin_Turbo's Avatar
Re: Trouble Starting and idle issues
What color smoke? blue? black? Could be CTS or poor CTS connection.
Old Nov 25, 2008 | 07:54 PM
Blue smoke.
What is CTS?
Thanks.
Old Nov 25, 2008 | 09:21 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
my car does this when it's cold it will start then stop but if u hold the gas in just a little it will stay going, all the sensors are new but only happens when it's close to freezing
Old Nov 26, 2008 | 02:04 AM
Twin_Turbo's Avatar
CTS = coolant temp sender. If the connection is bad the car will get excessibe fuel. However, blue smoke is oil.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
