Question
Old Nov 29, 2008 | 06:28 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Question
I have a 91 firebird 305 tbi im getting a cam and intake put in do i need to upgrade my fuel pump thanks
Old Nov 30, 2008 | 01:12 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Question
Stock tbi fuel pump max is around 14psi, the stock injectors at 14psi should support 200hp.
You can also increase injector size, but will have better results by using the smaller injectors with higher fuel pressure.
Old Dec 1, 2008 | 02:14 PM
Ronny's Avatar
Re: Question
I think the only way to know is to test the stock pump on a modded engine by monitoring the FP at WOT/heavy load. I have not done so but others have run a TEMPORARY line to a FP gauge and taped to windshield. Others have had a passanger hold gauge inside car. Not the safest way of monitoring however!
Old Dec 1, 2008 | 09:37 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: Question
yeah i have a fuel pressure gauge inside my car but not hooked up because of the unsafeness thats why im getting a bond on hood cowl to saw zaw a square sheet out of the stock hood so the engine gets air and to put the gauge there. thanks Ronny fo the update .
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
