305 to 350 and now it idles up and dies
Old Dec 1, 2008 | 11:52 PM
girlmit91's Avatar
Ever since I took my stock 305 out and swapped with the 350vortec motor (kept the TBI), my car will idle fine at start-up and sound healthy until I try to take off. Sometimes it just bogs down and tries to die when I try to accelerate and other times it will idle UP and then DOWN and UP and DOWN and then sometimes it will idle down hard enough that it will kill itself. Any thoughts? I've been fighting this for a year now...
Old Dec 2, 2008 | 11:09 AM
Ronny's Avatar
Re: 305 to 350 and now it idles up and dies
Sounds like my engine day one of mods. I would start with a datalog and see what your sensors are seeing.
what is coolant temp when you try to move car? If you allow it to come up on temp to 165F(closed loop) is the result the same?
Old Dec 2, 2008 | 11:42 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
tps or IAC but it sounds like a flat spot in the tps. Or the MAP sensor is shot
My 92 tbi does the funny idle thing where it goes up and down and bogs on me sometimes on the start but I have a manual so I can feather the clutch.
Jake_92RS
Jan 28, 2020 10:37 PM
jklein337
Sep 19, 2018 06:23 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
