Venom Injectors 454
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Venom Injectors 454
will these injector fit in a 305 tbi unit beacuse im looking to get higher fuel pressure without switching the fuel pump for the engine to run fine with a cam and intake going on?
http://www.jegs.com/i/Venom/735/HP647-222-2/10002/-1
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: Venom Injectors 454
All the TBI injectors are interchangeable.
You NEED a new fuel pump though to increase PSI or run bigger injectors.
I wouldent trust a 15+ year old fuel pump with a modified motor though.... Youre going to have to bite the bullet and get a new pump. The flow from the stock fuel pump is pretty crappy.
454 injectors are way overkill. IMHO. I would up the FP only and see how that works out. If you find you need more fuel then step up to 65 lbs cop car injectors. Odds are with a mild cam upgrade the stockers are fine.
Car: 1991 Trans Am
Axle/Gears: Stock
oh ok i was gonna say because i just bought brand new ones from checker for 265.00 didnt want that to goto waste so after the installation and ill see how the car runs if its fine then ill leave it alone thanks Ronny
thejimsterz28
Sep 15, 2015 04:37 PM
