big injectors ???
Old Jan 12, 2009 | 01:51 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
big injectors ???
hello, , I was thinking of possably using 80 or 90 lb injectors in my crossfire injection.--- Do you think thats def to big ???? or may work. ---Im a 355 eng,-- eldebrock tubular headers,--- 3 inch exaust,, No cat conv,,---ported intake,,- 2 inch t/bodys.-- Pro Topline, Pro lightning cast heads,, - P.S. i USE tuner pro to tune with the prominator .
Old Jan 12, 2009 | 04:50 PM
Ronny's Avatar
Re: big injectors ???
check this out:
http://www.users.bigpond.net.au/ben_...ctorsizing.xls
I would consider about 25-30 lbs might be max on injector FP. Maybe others ran them higher. your duty cycle in log will determine if you need higher FP or larger injectors. I would keep cranking up your current ones and see how it responds B4 investing the $$$.
Old Jan 14, 2009 | 12:19 AM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
read this
http://www.megamanual.com/v22manual/minj.htm
Old Jan 19, 2009 | 10:32 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
The only reason to run 80-90lb injectors is if you are going to be above 350hp. You can increase your fuel pressure (assuming you have a nice pump, regulator spring, etc) to make your current injectors flow at a higher rate to support your hp. An example... 65lb injector flowing at 29psi will handle 370hp. 90lb injectors flowing at 16psi will handle about 365hp. So, it all depends on what you want to do.
What are the injector ratings on the crossfire systems? I know the front and rear injectors are different.
If you need gasket/o-ring kits for your crossfire or IAC Valves, throttle position sensors let me know.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
