out with the old, in with the umm less old
Old Mar 30, 2009 | 11:54 PM
  #51
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: out with the old, in with the umm less old
The harness on the driver side = leave it alone. Driver side harness is used to power the rest of the car, headlights, ignition power to the coil, etc!!
From one of the photos it looks like you have extracted old CCC harness in one piece - that's exactly what you want!!!
Old Mar 30, 2009 | 11:56 PM
  #52
RFmaster's Avatar
Car: 75 Beast
//RF
Old Mar 31, 2009 | 12:06 AM
  #53
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Yeah, it took some gentle lovin' but she came for me. Do I need to delete out some of the leftover wires? can I just clip them can cap em'? Or is there some other mundane way of doing this that I'll have to go through?
Old Mar 31, 2009 | 12:21 AM
  #54
RFmaster's Avatar
Car: 75 Beast
Hold off on deleting stuff at this time.
Make sure that you have ignition coil power lead - pink 10AWG wire identified as well as tachometer. Locate FP relay - look for gray and red wire (this should have been part of your old harness).
AC, stuff can wait. everything else can stay as is for now.
//RF
Old Mar 31, 2009 | 12:51 AM
  #55
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
would there be a relay for a mech fuel pump?
Old Mar 31, 2009 | 09:56 AM
  #56
RFmaster's Avatar
Car: 75 Beast
Oups - typo on my part - Carbed cars still used mechanical FP. Your donor harness should have a FP socket (BOSCH style). If this is not the case you'll have to do some basic wiring. It is easy do - you'll need socket, relay and correct size wires.
You'll have to drop gas tank and install in tank FP. When you drop gas tank take a look at gas tank wire harness and number of fuel lines connected to the fuel sending unit. If you see gray or light tan wire (10AWG size) thats the FP power lead. In '86 both FI & Carb were offered in camaro.
//RF
Old Mar 31, 2009 | 06:58 PM
  #57
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
So did they typically use the same tank for both apps? meaning there'd be provisions for the pump?
Old Apr 1, 2009 | 01:53 AM
  #58
RFmaster's Avatar
Car: 75 Beast
There are two different part numbers called out for Carbed and EFI gas tanks. I am guessing that GM did not put baffles in carburetor specific gas tank. Spectra Industries lists GM27A1982-1987 Camaro(4BBL) and GM27B for FI applications. Fuel pickup is a very specific item for EFI should have four fuel ports, Wires: 3; Sender unit (0-95 Ohms); Notes: SENDER; INCLUDES FUEL SENDER, FLOAT AND STRAINER (FUEL PUMP NOT INCLUDED); w/ Harness Codes: FPH, FEG, FES Part #: GAS-FG20A
Carburetor version does not use in tank fuel pump.
//RF
Old Apr 6, 2009 | 08:38 PM
  #59
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Okay, what does a bosch style socket look like exactly? I was wondering, do those tach and batt wires from the old coil setup need to be adapted to the new ones? and many other little things... I put the car up on ramps today so I could finish setting up the tranny wiring and bolting her up, but I realized that I need to lift the motor up a few inches again so I can route the wires to the back of the tranny better. I decided to start hooking up the power steering hoses, so yeah.. that's done now...what shall I do next?
Old Apr 7, 2009 | 09:37 AM
  #60
RFmaster's Avatar
Car: 75 Beast
There are couple of styles of BOSCH relays out there - Square and oval, with later being newer style
Oval
Square
PT152 or PT153
http://www.acdelcotechconnect.com/pi...s/gm/pigtails/
(7131, page 17)
http://www.barnesdistribution.com/pd...cle_81-100.pdf
http://www.clipsandfasteners.com/GM_...r_p/a19553.htm
//RF
Ions91Z28
Feb 14, 2002 01:50 PM
Roshambo
Pacific Northwest Region
Dec 11, 2001 03:30 PM
tacoboy
Oct 25, 2001 01:47 PM
dhirocz
Jun 18, 2001 02:10 AM
