I'm stumped and need help quick
Old Jan 25, 2009 | 01:16 PM
chevyracer8262's Avatar
My tbi 350 just started idling extremely rough and running very rich. I tested and replaced the tps, cts, dist cap and rotor, map, and the iac. So I tested the vacuum @ idle and the gauge is fluctuating very very iratic between 10-20"s but when you crack the throttle about 1/4 open and the vacuum gauge steadies pretty good but still fluctuates. Does anyone have any idea what could cause this? I think the vacuum problem is the source of all my issues because the map doesn't have proper vacuum. The entire top end of the engine has been redone less than 5000 miles ago. But I removed, cleaned an regaped the spark plugs and found out the no 4 plug was completely gunked up with carbon.
Old Jan 25, 2009 | 01:37 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: I'm stumped and need help quick
Hey racer
You need to dig a bit deeper, but based on your description vacuum readings that change quickly indicate sticky valve guides, burned valve sets, or leak in head gasket. It also depends which vacuum tap you are using to measure for your vacuum gauge. To be more specific, if vacuum gauge reading is vibrating excessively at idle but steady at higher engine speeds this may indicate worn valve guides. It also can be indicative of a bad ignition miss for one or two cylinders - rapid vacuum swings between 20 to 10 in-Hg.
My next steps would be:
1) Perform a cylinder leak down test to make sure that guides, valves are not leaking.
2) Check spark plug wires, replace them to be certain.
Good luck and keep us posted
//RF
Old Jan 25, 2009 | 01:42 PM
It has all new dist cap, rotors, plugs and plug wires.
Old Jan 25, 2009 | 10:21 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
EGR valve?
Old Jan 26, 2009 | 05:28 AM
it doesn't have one and hasn't had one since i got it running the intake i'm running is a non egr intake
Old Jan 26, 2009 | 07:40 AM
MCN "Queue"'s Avatar
Car: 91'RS comaro
Engine: stock 305
Transmission: ??? it works????
Axle/Gears: yep it rolls
Does you vehicle have AC......if it does have a close look at the connector for the vacuum selector. when rough hands pull this control head from the consol the fastener clip gets it's dogs broken off this leaves the 2 halves of the Vacuum selector wide open and this is the same as pulling a vacuum line off the intake.....I put a screw in between the clip jaws and pulled the vacuum selector halves back together solved the vacuum leak smoothed out my idle very nicely.....might be your is the same issue.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
