2.02" / 1.60" valves work in a 3.735" bore?
Old Feb 8, 2009 | 02:59 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Just wounding if they will fit from my understanding it depends on the cylinder heads. iv heard it will work and iv heard it wont. i know some racers have used these sized valves on 0.60 over bored 305 blocks. so whats the deal? would these size valves in any head work with a stock sized bore ?
Old Feb 8, 2009 | 03:18 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: 2.02" / 1.60" valves work in a 3.735" bore?
I'm only guessing but...the reason is "shrouding the valves" on stock style motors. The larger valve in the smaller bore will push the in coming flow into the cylinder wall. so the larger valve will cost power in that case. now on a race motor you could run a much higher lift to get the valve out of the way, so the valve head will be less likely to direct the in coming charge into the cylinder wall.
Somebody else will need to help with the information in regards to if the 2.02 will fit or not.
hope that helps.
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
89-S-dime
Aug 12, 2015 11:57 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
